I picked up your post
yesterday when looking for something else. Thank you for that excellent app that works like charm.
How about automatic trip log? Trigger logging, for example, by connecting phone to certain BT (car) and use GPS to log start and stop addresses as well distance travelled.
Afterward you could select what type of trip it was (private, work etc.) and maybe have some export options to csv.
Pantry has one coming - fiat penus, but hasn’t shown up on jolla store yet, is submitted to chum also. If you can’t wait, and feel you trust me then here’s the rpm Release fiat penus 1.1 · munksh/FiatPenus · GitHub
Otherwise you can wait, knowing it’s coming soon ![]()
Do you think it could be possible to publish on Github the open code for Suomalaiset Pyhäpäivät?
Would be appreciated
Oooh but i think you actually did
Maybe it would worth to put the link in the Jolla Store description of the app ![]()
Yes the 0.5v has the changes to the store.
The upmpdcli stuff with MPD? Described in openrepos: Jupii | OpenRepos.net — Community Repository System
I’ve been working on this recently. The app supports various services such as DeepL and LibreTranslate. I’ve also integrated translation via an LLM; Mistral is currently integrated, but it will be possible to use OpenAI via the ‘Custom LLM’ option.
So nice!
Do you think you could include yandex translate as well?
I’m currently not a SailfishOS user, but used PocketPal on Android a bit with a 8 GB phone. token/s with Gemma-3-4b-it-UD-Q4_K_XL were ok/usable, but hallucination was a problem. Possibly a bigger model (with the 12 GB Jolla) or a small model for a specific usecase would work better in terms of content/correctness. Have you tried anything else here?
For those, who want to develop even using only Sailfish OS device.
Hey haha, i didn’t try much since then and thanks for reminding me cause i notices some developments. I ran smilar model in PocketPal on JollaPhone 2 in the android compatibility layer and it run with roughly 7 tokens/s which is usable but kinda slow. Not bad considering it was the compatibility layer tho. Bonsai ran much faster but that is just bonsai. I noticed that someone managed to run llama.cpp on the jolla phone and there are native apps that can connect to open AI universal api now so i mean seems like native local AI is indeed very doable. Howeveeer apparently this CPU in Jolla phone has no NPU cores or Ai optimization and overall Mediatek chips aren’t well supported in llama.cpp so the performance people report is no better than what i had in the android app. There have been some comments that the llama can be tweaked to not use GPU at all and to use only the performance cores to make it behave better but seems like it doesn’t help all that much. I might give this a try tho.
This topic is getting out of hand am asking to close it since i dont know how and starting a new one.
