REPRODUCIBILITY: 100%
BUILD ID: Rokua
HARDWARE: XA2
UI LANGUAGE: English
2 Reboots after update to 3.3.0.16 (after purchasing license), when the phone discharged to 25%, I started getting a notification sound (a short jazzy piano blip) once a minute. This sound corresponds to no selected sound under Settings => Sounds. I have also UNchecked System sounds.
At home I connected it to a charger; I think it stopped for a while there, but then I started getting a different sound (a short glockenspiel chord), exactly every minute. At precisely that time I find the same recurring line in the journal:
Aug 26 20:36:38 XperiaXA2-DualSIM kernel: swr-wcd msm_sdw_swr_ctrl: swrm_cleanup_disabled_data_ports: end of list
- discharge battery to 25% and continue discharging => piano blip every minute
- while charging battery => short glockenspiel sound every minute
- disconnecting the charger makes it stop
No sounds at all.
Repeating sound that cannot be switched off and does not identify itself
I was trying to get Android support working, without success. I don’t think it’s connected but worth mentioning.
Full journalctl output: https://paste.ubuntu.com/p/hhhV8hjqPQ/
