Android appsupport - YubiKey is not recognized
REPRODUCIBILITY: 100%
OS VERSION: 5.2.0.16
HARDWARE: Jolla Phone 2026
UI LANGUAGE: English US
REGRESSION: Don’t know
Android apps that require YubiKey verification does not recognize the connected YubiKey
Service with YubiKey enrolled for authentication (Google account, 1Password)
  1. Login into 1Password for example
  2. When asked to connect the YubiKey, insert it into the USB-C port
YubiKey will go into confirmation mode (blinking button waiting for physical press)
Key briefly blinks when powered on and stays inactive
I don’t believe the USB-port is routed to the AAS. If you have a deeper knowledge of the inner workings of Linux, maybe you can try route it yourself to see, if it is possible?
Btw, same with the NFC, so don’t bother trying with YubiKeys with NFC either.
(It has been asked, if Jolla could find out if it is possible to pass the NFC to AAS, like they did with BT)
I’m not sure this is likely. There is virtually no description, let alone documentation for Alien Dalvik from a quick search. I see lxc configs available, maybe I can poke something there, but this sounds like a very bad idea :slight_smile:
I would also love to have NFC working in AAS as i use my NFC YubiKey a lot. Does it recognize the Yubikey via NFC in the native browser?
No, the native browser does not process the passkey prompt. I think it’s too old of the firefox engine. Looks like Firefox added passkey support in version 122, while Sailfish OS 5.2.0.16 ships with 115
Not a bug - just a known limitation.
This has been discussed several times before.
