REPRODUCIBILITY: Intermittently
OS VERSION: 4.4.0.68
HARDWARE: Xperia XA2 H4113
UI LANGUAGE: Danish
REGRESSION: Yes
Android apps such as e.g. the BirdNET app freeze randomly. I have to stop and start Android App support from the settings menu. It may be that it is simply android app support that crashed in the background.
None in particular?
This is an intermittent problem, but for instance …
- Start BirdNET app
- Tap the “Record” button to record a bird sound
After having recorded the bird sound, I should be able to tap “Analyze” to send the sound file to the server for analysis.
The app freezes so I cannot send the recorded sound file to the server for analysis.
I have microG Services installed, if that may mean anything.
