AAS + positioning = crash AAS (impossible to use navigation apps)
REPRODUCIBILITY: 100%
OS VERSION: 4...*
HARDWARE: Sony xperia 10 II, XA2
UI LANGUAGE: RU
REGRESSION: restart dalvik
when dalvik use gps, they crash, for fix it I restart dalvik via settings
apps for test: 2gis, yandex.navigator, telegram*
*example: open telegram => main menu => peoples near u (for start positioning)
try interact w/ tetegram or wait, after few minutes dalvik crash
need dalvik and app for use positioning
  1. buy and install alien dalvik
  2. install some Android app for using positioning (ex. telegram, yandex.navigator, 2gis)
  3. enable positioning
  4. start android app
  5. wait few mins
  6. try interact w/ dalvik (opened app)
I’m expect working apps
dalvik crashed and not restart automatically
using some navigation apps is impossible
I use patchmanager w/ some patches, but I try test it on fully cleaned xperia 10II (after 1st flash from android to sailfish)
It happens to me (XA2 plus, 4.4.0.68) sometimes, when GPS hasn’t got a fix yet with Waze.
what is this, fix via waze? I don’t know about waze
Waze is a navigation app (for iOS and Android).
Happens to me using HereWeGo
I can confirm this behavior on my XA2. Initially i thought it’s a memory problem but after tweaking and thinking I came to this conclusion.
Can some of you try osmand and see if that crashes as well?
I am using it for hours without problems. Would be interesting to see if it depends on the app
Osmand crashed after aprox. 1 minute of usage. I just scrolled the local area.
Did you get a gps lock in this time? Does it also crash if you disable gps?
Did not get a lock. With deactivated GPS the nav apps seem not to freeze.
yes, when positioning disabled or in search status, apps doen’t freezing, but when positioning getted, apps get freeze
Can you add this info to the first post, so its easier to find?
Thank you for trying, that is helpful I think!
i cant edit 1st post, sadly
@flypig can you do this?
yep, same sh##t on XA2+ every time when use any GPS application…
but on 10 III it works better, it crash some times, like 2 crashes from 10
Same here on h4113 with Mapy.cz app. I think it started with Sailfish 4.3.
Thanks for reporting this @podbot_2_5, and sorry that you’ve been experiencing this. I’ve created an internal bug report about it and tagged this here as “tracked”. If there are any updates on this to share in the future, I’ll do my best to post them here.
I do confirm this bug. The last update (0.68) brought the stuff a bit better, still I do experience it sometimes.
Hardware: XA2
Software: Waze, Magic Earth
Thanks for confirming that you still experience it @GiT. It’s always useful to know that bugs are still current.
Are you running Sailfish OS 4.4.0.68?
Indeed, ma friend. Sorry for not having it mentioned already. :slight_smile:
