The digitizer of my Xperia X is broken. Left side of the touch screen (1cm) doesn’t response anymore. It makes me rotate the phone like a helicopter to be able to use it right. :))
Would it be possible to change the size of the display, so that I can use 1cm less of my display on left side (and up) in order to have full functional phone again? Like changing the scale of the GUI?
Cheers.
