REPRODUCIBILITY: 100%
OS VERSION: 5.2.0.16
HARDWARE: Jolla Phone (2026) (jp2601)
UI LANGUAGE: English (US)
REGRESSION: has not been working ever since I got the device
Bluetooth LE HID peripherals (HID-over-GATT / HoG) pair, bond, connect and report battery
level correctly, but no evdev node is ever created for them, so they produce no input at
all. Bluetooth is otherwise fully functional: A2DP over BR/EDR works, and non-HID GATT
devices work. The failure is specific to the HoG path.
Any Bluetooth LE keyboard or mouse exposing the HID service (UUID 0x1812). Developer mode is needed only to observe the cause, not to trigger the bug.
- Pair a Bluetooth LE keyboard or mouse from Settings > Bluetooth.
- Confirm it connects:
bluetoothctl info <MAC>reportsConnected: yes, LE.Connected:yes, and a valid battery percentage. - Type on the keyboard / move the mouse.
- Compare
ls -l /dev/input/before and after connecting.
A new /dev/input/eventN node appears on connection and the device generates input.
No new node appears. No input is received. bluetoothd logs “input-hog profile accept failed” for the device.
- Developer mode enabled
- libpebble3d installed. It ships
/etc/systemd/system/bluetooth.service.d/50-libpebble3d.conf, which setsEnvironment=TRACING=-E(exposing bluetoothd’s experimental D-Bus APIs), but the bug reproduces identically with this drop-in removed and bluetoothd running without -E, so it is not a factor. - /etc/systemd/system/bluetooth.service.d/99-uhid-fix.conf added as a workaround while
investigating (see below). The bug reproduces with this file absent. - Chum, Storeman, but just for user facing applications
Devices tested:
| Device | Transport | Result |
| Clicks Power Keyboard (Appearance 0x03c1, icon input-keyboard) | HoG | connects, bonds, battery OK, no input |
| BLE mouse (Appearance 0x03c2, icon input-mouse) | HoG | connects, bonds, battery OK, no input |
| Sony WF-1000XM5 | BR/EDR (A2DP) | works |
| Pebble smartwatch | BLE / GATT, non-HID | works |
bluez version: bluez5-5.87+git1-1.16.1.jolla.aarch64
Running the identical binary with identical arguments manually from a root shell makes the keyboard work immediately.
Temporarily relaxing the node permissions also resolves it:
chmod 0666 /dev/uhid && systemctl restart bluetooth
After reconnecting, a new /dev/input/eventN appears and both devices work normally.
Workaround (confirmed working):
A minimal drop-in granting the intended group access without weakening the rest of the
unit’s hardening:
[Service]
SupplementaryGroups=uhid
