REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.68
HARDWARE: X10 III
UI LANGUAGE: ru
REGRESSION: yes
ADAPTATION: 1.0.0.142
Multi touch keyboard was broken. I always use one finger to hold shift key, and another to press letters on keyboard. On XA2+ 4.4.0.64 this work as expect, its print uppercase letters, but on my 10 III, when i hold shift key , first pressed letter not shown, next pressed print as uppercase, third pressed print as lowercase … this so annoying! )
Open some message application, like notes, create new note, then tap on edit filed, wait when keyboard was shown
- open some text edit application, like notes ( or any messenger, even from dalvik )
- tap on edit field, wait while keyboard was shown
- hold one finger on shift key, start typing work by another finger (with another hand
all letters should be in uppercase
first letter not shown, second in uppercase, other letters are lowercase …
Maybe is some hardware bug, cant say, dont check this case when this device was with android os. On portrait orientation i have same result, but if i press shift with more area (press stronger), looks like its hold pressed ( maybe it really hardware bug, with touchscreen )
gif with bug
Every word entering with hold shift key
Confirmed, this is 100% bug of maliit keybord, because in finger term i can hold Shift key and print uppercase words!
