Hi all,
I’ve recently moved onto Xperia 10lll device, from Xperia X.
Generally all good but I seem to have reintroduced the bug that meant my xperia X ended up unusable (& had presumed was a hardware fault)…
When attempting to restore from backup it failed at ‘Notes’. I managed to add Contacts and Calendar after unpacking the .tar backup and also installed Notes after deleting everything else out of a copy of the .tar file but the Notes dir and re-running the backup restore.
The problem I’m having is that the phone charges very intermittently, often saying it’s charging (top-left battery icon has horizontal line and the green led is lit) but it just drains rather than charges.
Noticeably too when attempting to shut the phone down it reboots if cable attached (& freezes at the Sony splashscreen).
This wasn’t happening before I restored the backup btw.
Would really appreciate some wisdom/guidence on possible solutions for this…?
Do wonder if there’s some conflict moving from Nemo to Defaultuser. Is there a way to check there’s no Nemo left anywhere (kinda reverse request to the ‘change defaultuser to nemo’ thread:).
There was also my old user account added after the Restore, which I just deleted without thinking of any possible implications. I dunno, clutching at straws tbh. Is it reflash time and add files individually - which would be major pain as have spent the weekend setting everything up again (various apps, vpn, etc. etc…).
Hi Attah, thanks for quick response.
Yep, tried couple different chargers and plug combos (inc new cables).
I get different results from the same setup (cable/plug) too.
So atm after another restart(vol-up reset) phone is charging again, whereas all last night it was plugged in and the battery this morning was -10 lower than when plugged in.
I too find it weird but the fact that this killed-off my old xperia x as being useful and is now happening on my nice shiny new phone makes me think it has to be something software-related.
How did those tests with different (how many?) chargers go? You kinda glanced past that…
Maybe you have a very noisy electricity grid where you live. Can you reproduce while charging from a powerbank or unplugged laptop?
Home is a 4 bank usb (2a) plugged into mains. Also tried 2 different usb-plugs this morning (borrowing from work colleagues, with different usb-c cables). One was a fastboot charger and that didn’t register at all. Tried it plugged into my lappy too this morning (but wasn’t unplugged). It wasn’t charging this morning from mains at work but did start after the mentioned earlier hard reboot.
These are totally different chargers/cables than those used with my old phone btw.
I need to collect kids but back online in an hour or so…
Brands, (fast-)charging standards etc is what would be relevant. Like, are they reputable? Is there a pattern? What about the charger that came with the device? Number of outlets and available amperage says very little.
This is not a thing - which makes me wonder if i should doubt more things.
But if you want to look at system logs, you can always (from the developer mode terminal) run: devel-su journalctl -f
Probably best to enable ssh and log in that way btw, so you could copy anything interesting.
Although i still very much doubt it is a software issue.
You can also monitor charging with Battery Buddy (and it also limits the max charge by default, just so you know). It tells you if the charger is connected, what the status is, and how fast it dis/charges. My X10III worked and works just fine before and after restoring the backup.
TBH, I don’t know how restoring a backup could mess with charging… I can’t say it’s not possible, but quite darn unlikely…
Hello,
Yes, reputable chargers/cables afaict, work with an assortment of other household gadgets.
"What about the charger that came with the device? "
Hmm, sore point. I have teenage children, we’re not allowed to have nice things (esp. with ones that come back for couple days and then disappear). I’ve ordered an allegedly Sony one, will see if makes a diff.
“This is not a thing(fastboot)”
Yeah, ok, fairpoint. Like I said, they were borrows from work colleagues.
Anything in particular I should be looking for here?
There’s a lot of this:
‘Jun 06 21:05:34 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010’
Sample output:
– Logs begin at Mon 2022-06-06 21:02:17 BST. –
Jun 06 21:11:54 Xperia10III kernel: [schedu][0x4b60f2e0a][21:11:54.096375] wlan: [5011:I:OSIF] vdev 0, scan id 40991 type COMPLETED(1) reason COMPLETED(1) scan found 6 bss
Jun 06 21:11:55 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:11:56 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:11:58 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:11:59 Xperia10III kernel: rpmh_rsc_send_data: 4 callbacks suppressed
Jun 06 21:11:59 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:00 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:01 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:02 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=246, batt_id_ohm=15000
Jun 06 21:12:02 Xperia10III healthd: battery l=71 v=4095 t=24.6 h=2 st=2 c=366516 fc=0 cc=0 chg=a
Jun 06 21:12:02 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:6992
Jun 06 21:12:02 Xperia10III mce[1929]: modules/battery-udev.c: mcebat_update(): battery_level : 70 → 71
Jun 06 21:12:04 Xperia10III kernel: rpmh_rsc_send_data: 24 callbacks suppressed
Jun 06 21:12:04 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:04 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:04 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
Jun 06 21:12:04 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=245, batt_id_ohm=15000
Jun 06 21:12:04 Xperia10III healthd: battery l=71 v=4102 t=24.6 h=2 st=2 c=440063 fc=0 cc=0 chg=a
Jun 06 21:12:04 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:6992
Jun 06 21:12:05 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:05 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:07 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:09 Xperia10III kernel: rpmh_rsc_send_data: 22 callbacks suppressed
Jun 06 21:12:09 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:10 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:11 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:11 Xperia10III healthd: battery l=71 v=4104 t=24.6 h=2 st=2 c=416260 fc=0 cc=0 chg=a
Jun 06 21:12:13 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:14 Xperia10III kernel: rpmh_rsc_send_data: 14 callbacks suppressed
Jun 06 21:12:14 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:16 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:18 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
Jun 06 21:12:18 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=245, batt_id_ohm=15000
Jun 06 21:12:18 Xperia10III healthd: battery l=71 v=4103 t=24.6 h=2 st=2 c=444031 fc=0 cc=0 chg=a
Jun 06 21:12:18 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:6992
Jun 06 21:12:18 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:18 Xperia10III booster-qt5[5584]: *** signal=17 pid=5584
Jun 06 21:12:19 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:20 Xperia10III kernel: rpmh_rsc_send_data: 17 callbacks suppressed
Jun 06 21:12:20 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:22 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:23 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:25 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:26 Xperia10III kernel: rpmh_rsc_send_data: 5 callbacks suppressed
Jun 06 21:12:26 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:27 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 69 1 0 0 0 0 0
Jun 06 21:12:27 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:1004 y:1684 z:35 major:9 minor:9 tc:1 type:0 noise:0
Jun 06 21:12:27 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 69 0 0 0 0 0 0
Jun 06 21:12:28 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:67 tc:0 lx:846 ly:1725 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Jun 06 21:12:28 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:29 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:29 y:1163 z:22 major:5 minor:5 tc:1 type:0 noise:0
Jun 06 21:12:29 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:72 tc:0 lx:697 ly:1404 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Jun 06 21:12:29 Xperia10III kernel: [schedu][0x4dee319e8][21:12:29.770181] wlan: [5011:I:OSIF] scan start scan id 40992
Jun 06 21:12:30 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:848 y:2499 z:23 major:6 minor:6 tc:1 type:0 noise:0
Jun 06 21:12:30 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:23 tc:0 lx:985 ly:1904 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Jun 06 21:12:31 Xperia10III kernel: pm7250b_charger: somc_aicl_irq_handler: IRQ: aicl-done
Jun 06 21:12:31 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=244, batt_id_ohm=15000
Jun 06 21:12:31 Xperia10III healthd: battery l=71 v=4088 t=24.7 h=2 st=2 c=233154 fc=0 cc=0 chg=a
Jun 06 21:12:31 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:6992
Jun 06 21:12:31 Xperia10III kernel: rpmh_rsc_send_data: 23 callbacks suppressed
Jun 06 21:12:31 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:31 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:31 Xperia10III kernel: binder: 7146 RLIMIT_NICE not set
Jun 06 21:12:32 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:409 y:797 z:42 major:11 minor:11 tc:1 type:0 noise:0
Jun 06 21:12:32 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:5 tc:0 lx:411 ly:796 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Jun 06 21:12:32 Xperia10III lipstick[5854]: [W] unknown:0 - QFSFileEngine::open: No file name specified
Jun 06 21:12:32 Xperia10III lipstick[5854]: [W] unknown:264 - file:///usr/share/lipstick-jolla-home-qt5/launcher/LauncherGrid.qml:264:9: QML LauncherIcon: Failed to get image from provider: image://theme/emacs
Jun 06 21:12:32 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:33 Xperia10III kernel: sec_ts 1-0048: [sec_input] [P] tID:0 x:410 y:802 z:42 major:11 minor:11 tc:1 type:0 noise:0
Jun 06 21:12:33 Xperia10III kernel: sec_ts 1-0048: [sec_input] [R] tID:0 mc:3 tc:0 lx:410 ly:804 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
Jun 06 21:12:33 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=245, batt_id_ohm=15000
Jun 06 21:12:33 Xperia10III healthd: battery l=71 v=4068 t=24.7 h=2 st=2 c=103759 fc=0 cc=0 chg=a
Jun 06 21:12:33 Xperia10III kernel: ALG: cap_learning_update: [SOMC CL][OFF] charge_status:1 bsoc_cp:6992
Jun 06 21:12:33 Xperia10III kernel: QG-K: get_batt_id_ohm: batt_id_mv=243, batt_id_ohm=15000
Jun 06 21:12:33 Xperia10III healthd: battery l=71 v=4046 t=24.7 h=2 st=2 c=-82397 fc=0 cc=0 chg=a
Jun 06 21:12:33 Xperia10III lipstick[5854]: [W] unknown:0 - WindowPixmapItem does not have a source texture, cover will be dropped…
Jun 06 21:12:34 Xperia10III kernel: [schedu][0x4e40ab148][21:12:34.274142] wlan: [5011:I:OSIF] vdev 0, scan id 40992 type COMPLETED(1) reason COMPLETED(1) scan found 7 bss
Jun 06 21:12:34 Xperia10III booster-silica-qt5[11779]: [D] unknown:0 - Using Wayland-EGL
Jun 06 21:12:34 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:37 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
Jun 06 21:12:38 Xperia10III kernel: rpmh_rsc_send_data: 28 callbacks suppressed
Jun 06 21:12:38 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:39 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 06 21:12:40 Xperia10III kernel: binder: 7136 RLIMIT_NICE not set
After hard reset the cable attached to unplugged laptop charger for was spitting out circa 1200mA, now after soft/regular reboot it’s around 440mA.
Can I ask if other have the same issue with shutting the phone down with a charging cable attached and the phone reboots but freezes at Sony splashscreen?
Hi @direc85,
Thanks for headsup re battery status info. HT.
Yeah, I get it seems unlikely but it’s a strange coincidence. Guess I just need to keep trying things
