REPRODUCIBILITY: Unknown
BUILD ID = OS VERSION: 4.2.0.21
HARDWARE: Xperia 10 ii
UI LANGUAGE: Greek
REGRESSION: No
Sometimes, the device suddently stops notifying for incomming phone calls. When someone tries to call me, the phone does absolutely nothing, although the device seems to be OK with signal reception (the caller thinks that I do not pick up the phone since it is “beeping” from his side).
When this happens, I get an error pop-up “Network error” when I try to make a call.
Only a restart fixes the issue. Tried to enable-disable flight mode, but didnt fix the problem.
Note that, when the phone is in this condition, it doesnt freeze or lag, an one cannot understand that there is a problem until you try to make a phonecall.
I experienced this twice within 3 days.
Not any noticed
