[4.1.0][4.3.0] Gemini PDA still have call traces like on 3.4.0.22
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): geminipda
UI LANGUAGE: english us
look also: https://forum.sailfishos.org/t/3-4-0-22ea-geminipda-call-traces-on-wakeup/2472
geminipda has trace logs in the journal
none
start ‘devel-su journalctl -f’ in a ssh console and do:
close the lid
sleep 7
open the lid
sleep 7
goto 1)
no trace logs
trace logs in the journal like below
Jun 04 15:36:41 Sailfish kernel: [HIF-SDIO][I]mtk_wcn_wmt_func_ctrl:wmt-exp: OPID(3) type(9) start
Jun 04 15:36:41 Sailfish kernel: [Power/cpufreq] @_cpufreq_set_locked(), MT_CPU_DVFS_LL:(15,0): freq=1118000(1118000), volt =102000(102000), on=1, cur=481000, cci(325000,676000)
Jun 04 15:36:41 Sailfish kernel: [NVT-ts] nvt_ts_resume 1798: end
Jun 04 15:36:41 Sailfish kernel: [NVT-ts] nvt_ts_resume 1778: Touch is already resume
Jun 04 15:36:41 Sailfish kernel: [WMT-CORE][W]opfunc_func_on:func(9) already on
Jun 04 15:36:41 Sailfish kernel: [HIF-SDIO][I]mtk_wcn_wmt_func_ctrl:OPID(3) type(9) ok
Jun 04 15:36:41 Sailfish kernel: [HIF-SDIO][I]wmt_pwr_on_off_handler:WMT turn on LPBK suceed
Jun 04 15:36:41 Sailfish kernel: [Gsensor] bmi160_acc_read_sensor_data 1825 : acc final xyz data: 509,7621,7254, sens:8192
Jun 04 15:36:41 Sailfish kernel: ------------[ cut here ]------------
Jun 04 15:36:41 Sailfish kernel: WARNING: CPU: 0 PID: 185 at /home/abuild/rpmbuild/BUILD/kernel-3.18/kernel/irq/manage.c:454 enable_irq+0x88/0xd0()
Jun 04 15:36:41 Sailfish kernel: Unbalanced enable for IRQ 394
Jun 04 15:36:41 Sailfish kernel: CPU: 0 PID: 185 Comm: kworker/0:1 Tainted: G W 3.18.41 #1
Jun 04 15:36:41 Sailfish kernel: Hardware name: MT6797T (DT)
Jun 04 15:36:41 Sailfish kernel: Workqueue: events aw9523_key_eint_work
Jun 04 15:36:41 Sailfish kernel: Call trace:
Jun 04 15:36:41 Sailfish kernel: [] dump_backtrace+0x0/0x15c
Jun 04 15:36:41 Sailfish kernel: [] show_stack+0x14/0x1c
Jun 04 15:36:41 Sailfish kernel: [] dump_stack+0x80/0xa4
Jun 04 15:36:41 Sailfish kernel: [] warn_slowpath_fmt+0xb4/0xd8
Jun 04 15:36:41 Sailfish kernel: [] enable_irq+0x88/0xd0
Jun 04 15:36:41 Sailfish kernel: [] aw9523_key_eint_work+0x43c/0x5cc
Jun 04 15:36:41 Sailfish kernel: [] process_one_work+0x160/0x468
Jun 04 15:36:41 Sailfish kernel: [] worker_thread+0x140/0x4e4
Jun 04 15:36:41 Sailfish kernel: [] kthread+0xd8/0xec
Jun 04 15:36:41 Sailfish kernel: —[ end trace 5955ff4e4627c596 ]—
Jun 04 15:36:41 Sailfish kernel: __sched_setscheduler 524:mce policy=1 0 0
Jun 04 15:36:41 Sailfish kernel: CPU1: Booted secondary processor
Jun 04 15:36:41 Sailfish kernel: Detected VIPT I-cache on CPU1
Jun 04 15:36:41 Sailfish kernel: CPU1: found redistributor 1 @ffffff80000a0000
Jun 04 15:36:41 Sailfish kernel: CPU2: Booted secondary processor
Jun 04 15:36:41 Sailfish kernel: Detected VIPT I-cache on CPU2
Jun 04 15:36:41 Sailfish kernel: CPU2: found redistributor 2 @ffffff80000c0000
Jun 04 15:36:41 Sailfish kernel: [AAL] led_mode=5 , aal_need_lock=0
Jun 04 15:36:41 Sailfish kernel: CPU3: Booted secondary processor
Jun 04 15:36:41 Sailfish kernel: Detected VIPT I-cache on CPU3
Jun 04 15:36:41 Sailfish kernel: CPU3: found redistributor 3 @ffffff80000e0000
Jun 04 15:36:41 Sailfish kernel: [HPS] (0x7F00)<1>(0)(0) action end (100)(708)(0) (0)(0)(0) (4)(0)(0)(1)(0)(0) (0)(0)(708)(1) <4>(0)(0)
Is this an issue nobody cares? Or is it no issue?
But nice, I got an anniversary badged for it. I do not need that badged and give it to Jolla.
Why are you double posting? You could’ve updated the original topic.
Thanks, I think it is better to keep discussion on the original report if possible. @jolladiho, if there’s new info here that’s crucial to keep and can’t be transferred over, let me know and I can unhide your original post.
I would prefer to continue using this report, because I had accidentally uploaded a log with a custom kernel on the old report. It happens, because I tested with a kernel compiled by myself to check if it has that issue too. I thought that could be the reason nobody takes care of the bug.
And there was no discussion to keep. That’s why I did a link back to the old report. Please unhide this and hide the old one. That makes morde sence to me. Thanks
This is now the case.
Thank you very much. Much discussion misses the mark. :wink:
The problem still exists with version 4.3.0.12.
If there are no plans to solve the problem, then I can stop reporting about it here. Please reply.
journalctl -fb |grep trace
Nov 04 09:18:42 Sailfish kernel: Call trace:
Nov 04 09:18:42 Sailfish kernel: [] dump_backtrace+0x0/0x15c
Nov 04 09:18:42 Sailfish kernel: —[ end trace 958db83ab7f92525 ]—
Nov 04 09:18:43 Sailfish kernel: Call trace:
Nov 04 09:18:43 Sailfish kernel: [] dump_backtrace+0x0/0x15c
Nov 04 09:18:43 Sailfish kernel: —[ end trace 958db83ab7f92526 ]—
how can I update the original topic?
I do not find an edit and would like to tag it for 4.3.0.12.
Due to the wisdom of Discourse (and obeyed by Jolla) you can only edit your posts for a short time.
But title and tags should be possible? Or even that is not allowed for ‘normal members’?
Did it for you.
What actually is the expectation here?
AFAIK there is only that one Gemini kernel image so SFOS releases won’t change anything right?
I don’t quite understand the question. It is a bug report for an officially supported device from Jolla. Normally, bugs are fixed when they become known. Otherwise, the cathegory “bugreport” should be removed from the forum if it is not known what the user expects afterwards.
I’m not reporting it just for fun. If it will never be fixed, then it can be reported here and I save the effort of reporting it again on the next release.
