REPRODUCIBILITY (% or how often): Once
BUILD ID = OS VERSION (Settings > About product): [4.0.1.48]
HARDWARE (XA2, Xperia 10…): Xperia X
UI LANGUAGE: German
After failed OS Update Phone is stuck after first login.
unknown
- have aliendalvik-control 9.3.0-1
- upgrade via terminal to 4.0.1.48
- reboot
stuck after at first login
[66 %] [Remove] aliendalvik-control 9.3.0-1: [50 %]
Error: Subprocess failed. Error: RPM failed: Warning in file “/usr/share/applications/android-open-url-selector.desktop”: usage of MIME type “x-maemo-urischeme/http” is discouraged (the use of “x-maemo-urischeme” as media type is strongly discouraged in favor of a subtype of the “application” media type)
Warning in file “/usr/share/applications/android-open-url-selector.desktop”: usage of MIME type “x-maemo-urischeme/https” is discouraged (the use of “x-maemo-urischeme” as media type is strongly discouraged in favor of a subtype of the “application” media type)
Warning in file “/usr/share/applications/android-open-url.desktop”: usage of MIME type “x-maemo-urischeme/http” is discouraged (the use of “x-maemo-urischeme” as media type is strongly discouraged in favor of a subtype of the “application” media type)
Warning in file “/usr/share/applications/android-open-url.desktop”: usage of MIME type “x-maemo-urischeme/https” is discouraged (the use of “x-maemo-urischeme” as media type is strongly discouraged in favor of a subtype of the “application” media type)
/usr/bin/apkd-uninstall: line 41: 1: not found
/var/tmp/rpm-tmp.pZAnEB: line 32: syntax error: unexpected “fi”
error: %preun(aliendalvik-control-9.3.0-1.armv7hl) scriptlet failed, exit status 2
error: aliendalvik-control-9.3.0-1.armv7hl: erase failed
