REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.72
HARDWARE: Xperia 10III
UI LANGUAGE: Italian
REGRESSION: Yes
After the latest update of Whatsapp to app versione 2.25.34.12, when calling via app after the call is successfully connected, nothing can be heard by both participants to the call.
Xperia 10III with specified SFOS version installed + AppSupport + Whatsapp specified version
Start a call on Whatsapp
Wait for the call to be connected
The call audio can be heard by both sides
No audio on both sides of the call, not even forcing a different speaker/headset
N/A
Audio works normally within AppSupport (for instance, Telegram calls etc.).
Well I don’t know how to do that, but I was forced by whatsapp to update. So reverting to the latest usable version (which?) may end well in unusable whatsapp.
In Aurora store you can search for it and tap three points in the upper right corner on it’s page. Then choose manual transfer and input chosen version. I don’t know which version as I don’t use that WhatsApp function.
This is a workaround, but it won’t last long. At some point Whatsapp will stop working and require to install the new version. Any chance to get it working properly again?
For some strange, unknown reason it is working again. This sums up to all unpredictable behaviours of the system… Unfortunately with the low debugging knowledge I have & without some guidance I can’t help much.
