Keyboard question
I have used Swiftkey keyboard for a couple of years and like it. I am having trouble typing on the stock keyboard. I found an emoji/number row patch that I added. Wider spacebar patches are too old for 4.0.
Any suggestions?
Thanks in advance.
Hi.
@orangecat has a keyboard that you can check out.
If you want a swype keyboard, you can check out OKBoard
https://openrepos.net/content/eber42/okboard
already installed, an like, Multi. Skinny space bar is killing me along with no double tap for period…unless I just havent’ found the settings yet.
