How can I increase max volume
I have searched around and have only come up with a patch that hasn’t been updated since 2015 called max volume or something like that.
My speaker volume is too low and my call volume is too low to hear when I am driving.
What are you guys using as a workaround?
Thanks in advance!
As a hotfix i sometimes use the pactl set-sink-volume terminal command.
What device are you using?
For Bluetooth audio volume there’s btvol by fridlmue, available in chum
Here are more to this topic…
First, list the sinks:
pactl list sinks
pactl set-volume-sink 5 150% (0 is usually the primary out sink)
Oops, apologies…Xperia 10iii
I am guessing I did something wrong, but that command ( using sink 0 ) gets and error “no valid command specified”.
I double checked that I typed it like you listed it.
Can you post the full output of
pactl list sinks short
Typo. It should be:
pactl set-sink-volume 0 150%
I actually wrote that from memory, thus it was not necessarily correct.
For stuff like that you can always do a pactl --help or a man pactl to get an overview over the available options.
Almost everything supports --help and or manpages.
No worries.
I went to the Jingpad forums today to search how to do ssh as I couldn’t remember…turns out it was ME that wrote the guide I had to go find and read! :rofl:
Very similar I notice myself.
