Cannot recieve calls
Just installed SFOS 2 days ago and just found out I can not receive calls on either sim.No problem making calls, but when anyone calls me ( Thailand ) they get the “phone turned off” notice. I receive a “missed call” text almost immediately.
I also installed personal ringer off his git page, problem is I do not know 1) if I was receiving calls before that ( only tested making calls, not receiving after my install ) 2) how to remove that program if it is the offending issue.
Xperia 10iii, SFOS 4.4.0.72…not sure what other info you need.
Please supply a link to the git repo you installed from. Thanks!
Had I read the comment right below the link I clicked I would have seen it was causing this problem.
Once I removed personal ringtones ( couldn’t remember where I found it before ) and rebooted my problem was solved.
I now have functioning incoming calls.
